fablau said:
Yes, all this information is gold for us, thank you so much Vin.
I am really puzzled by the fact Tom can grow Walichii so well in a high traces environment. I can't think of an explanation for that. Can you?
A question for Burr: are you dosing macros pretty much at the same levels of this kill tank with the exception of N?
Thank you guys.
Recall I also add zero macros to my tanks in the garage and they do better than Pikez kill tank, with less dosing and attention.
The difference is the ADA AS, but it's old now, little N left.
Tanks are mostly N limited.
But, the clay soils hold vast amounts of trace metals.
So while you might wonder about the richer side, what about the even lower side?
ADA AS soil has ample trace metals and P.
So mostly N(NH4 via some fish/critter waste perhaps) and K/Ca/Mg(All water column).
I have urea. Been thinking about messing with the tanks out there.
Many folks go only one direction here, my advice is to master both directions, rich and lean(or very very lean so you see the effects of limitations specific to one nutrient).
And the richer side? Then once you master that, only then......can you really study the toxicity ranges.
Till then, you really cannot.
Note, I do not fiddle and obsess over the richer ranges, that's sort of the point, same with the leaner versions.
Any decent method will use that philosophy, because not one is going to really want to fiddle much with careful dosing really.
Look at Pikez or anyone(if they are honest), myself?
It's a bullshit sale, ferts really do not matter that much, light/CO2 really do.
So stick to that, then............see how far you can push the ferts.
For N, if you want to dose more daily carefully, then urea is likely a better blend, you can mix 50:50 with KNO3.
Dose about 1-2 ppm as N, so say 0.5-1 ppm as NH4 and 2-4ppm as NO3 a day(or once every 2-3 days etc).
