Dual Stage Regulators
Erilo
May 27, 2013
13
I have been reading throug this post for some days now and learned a lot more about regulators and I want to thank everyone who contributed to it.
On eBay I found three regulators that caught my eye and I wanted to ask the more experienced regulator builders to take a look at them and tell me which one is the best.
http://rover.ebay.com/rover/1/706-5...0001&campid=5338187531&icep_item=180577036843
http://rover.ebay.com/rover/1/706-5...0001&campid=5338187531&icep_item=160732902381
http://rover.ebay.com/rover/1/706-5...0001&campid=5338187531&icep_item=330792536692
I think the Tescom 64-3400 would be the best because of the stainless steel diaphragm and the low 30 psi outlet pressure.
Erilo
May 27, 2013
13
oldpunk;116715 said:
Stay away from the tescom. You don't want one with vcr ports.
See I was correct in asking you guys first. :D
Thanks Oldpunk!
How about that Victor regulator of $100? That one should be okay, right?
Or the $25 one?
oldpunk
Dec 1, 2009
427
The one for 100 looks like it's in a lot better shape. It's also much newer. The cheaper one is pretty beat up.
oldpunk
Dec 1, 2009
427
Kinda sucks that this thread has capped out. There's just so much really useful information.
I built a new one this morning and since this thread needs a bump:
oldpunk
Dec 1, 2009
427
Have you noticed if the gauges are sensitive to temperature changes? I think glycerin changes volume as it heats and cools.
alanle
Jun 10, 2013
210
14
I'm not sure if it's the gauges or the co2 cylinder but I do see the the pressure fluctuates a bit as temperature changes. This happens on non clycerin gauges as well.
alanle
Jun 10, 2013
210
14
Tom Barr;129576 said:
___How much__ temp change?
5F?
10F?
20F?
I keep the system in my garage. During midday when the temperature becomes unbearable (around 95F +), my high pressure gauge can spike up to 1000 PSI. As for the clycerine gauge alone, it can shift ~2% additional reading during a hot day. The cause is probably the change in the elasticity or spring rate of the Bourdon tube. Temperature, vibration and pulsation are three process conditions that can affect a pressure gauge. However these are not a main concern for our CO2 injection use.
This is my "garage" farming tank.
Just got this Tonnia from a member on this forum.
Yes my glossos are growing upward as most of the ground are taken by the hairgrass
Flyinghellfish
Dec 26, 2011
69
Anyone see those new Victors floating around? It's a revamp of their lower entry lines, I think they're plastic in the middle. Any advantages from plastic aside from lower cost? I' seen some other plastic regulators but they were all foreign European rigs.
GillesF
Nov 1, 2010
404
Antwerp, Belgium
Hi all
This is probably a silly question, but I've attached my needle valve to my solenoid valve, however, the plug of the solenoid valve gets in the way of the fine tuning needle. It would be perfect, if I could screw on the needle valve with 1 "turn" less. Can I solve this by using a robber O washer?
TimSc2013
Jan 1, 2017
I am new to Barrreport and I became interested in building interested in a DIY dual regulator after reading the related threads in the CO2 Enrichment forum. I am currently sourcing all the parts and was consider an in-line filter, such as the Swagelok Tee-Type (SS-4TF), after the regulator and before the solenoid to help prevent potential leakage due to small particles preventing the full closing of the valve when shut-off. Has anyone utilized a filter and if so what size filter element is recommended?
Stevek
May 23, 2016
Hey ... i have purchased a full dual stage SS here and am wondering where I can sell it on the Forum. I did not see the sales section.
Righteous
Subscriber
Apr 10, 2017
41
I'm researching regulators as an upgrade to my current fluval co2 system that is a pain to keep dialed in. I'm not sure how to evaluate the various regulators and systems I come across on eBay... for instance these vary in price significantly but I'm not sure how they are different. Is it simply a matter of trusting certain brand names based in others experience, or are there obvious ways to evaluate systems like these?
http://www.ebay.com/itm/CO2-Regulato...4AAOSwUEVYCmrN
kalkwasser
Sep 13, 2017
41
US
I have a question about the CG320 configure regulator if it can be use on a DIN (UK) valve by using a converter or some sort of a nut?
Is the thread opposite between the 2 cylinder valve? I always see the CG320 regulator are always on the left side while the DIN valve installed regulator are always on the right in term of operator viewing. Is that the main different?
86
CGA320 is the specification for the connection between a regulator and a pressurized gas tank. This specific one is used only on CO2 tanks. You can change almost any pressurized gas regulator to a CGA320 inlet by unscrewing the inlet nipple and installing the CGA320 nipple, obtainable from welding shops, online stores, etc. The side of the regulator where it goes is determined by the manufacturer of the regulator.
