EDDHA is only used in small amounts and typically for only folks with those higher KH's, say 8 or more.
That seems about correct, I'd still only use say 0.1ppm per typical dose of that type of Fe.
So with harder KH's,. I'd still use liberal amounts of DTPA+ EDDHA, not much.
Otherwise, stick with DTPA.
The only REAL method to test Fe with chelation is really to do 2 things with plants.
Know what you have dosed to the water, say you added 4ppm of Fe as 45% Fe DTPA, 50% ETDA, and 5% EDDHA.
Next measure what the dry tissue Fe content is.
I suppose you could also do growth rates, and measure the total dry weight biomass for each chelation type or blend and compare those. 6 ppm gave the highest rate of growth for Hydrilla, 8ppm gave the highest rate of uptake/ % Fe in tissue of the plant using ETDA Fe in one of the few applied studies on a submersed aquatic weed.
Quite a bit more than what typically is dosed by a hobbyist.
As I have the same product, I do not think there's going to be much difference in the weight of the Sequestrene 138.
