These look great. Do you happen to have the model numbers for the two airgas regulators? And what are the model numbers for the metering valves? Thanks!
I will need to shop around more and prepare for having a tank and stuff. A 5 lb tank would be fine? Also, these kinds of setups work with ceramic diffusers no?
Is there any solenoid that is 120v not 24v , reason I'm asking , I will have a bullet proof regulator as were the transformer I doubt is of high quality, that will be the weak point.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
