Gerry,
I agree. I appreciate your "guesses". I know there are more dirted tanks here. Let's hope they chime in
Jason Monette;92146 said:If the Mircle grow is the problem, why did it take 6 weeks after the tank was established to have green water? Others have used this setup with no Problem.
This is why I am so confused.
I appreciate all the suggestions!
Lets come up with a Plan of attack.
What should I try first? Here are my thoughts, let me know what you think.
1). Kill the Algea, uv sterilizer
2) major water change 90% once water is clear
3) get some fast growing floating plants
4) EI dosing
5) pump in tons of co2 and dose with excel
6) once good growth is established, remove uv
7) see what happens next
jerrybforl;92172 said:Now that I have seen the whole thread I would say it is definitely the MG! I would do several things.
1. add UV
jerrybforl;92172 said:2. I would do >50% WC daily or every other day.
jerrybforl;92172 said:3. I would switch my substrate. I will never use stuff that can cause issues later down the road.
jerrybforl;92172 said:4. Get rid of the fish that is stirring up the substrate. If you do (2), you don't have to get rid of any fish.
jerrybforl;92172 said:5. I would try to find a product that is designed to clear up GW.
jerrybforl;92172 said:6. EI
jerrybforl;92172 said:7. Do tons of research. Know what you are doing! Ask lots of questions.
jerrybforl;92172 said:8. Above all be patient.
jerrybforl;92172 said:I read that you said to "pump tons of CO2". Please be careful with this. Start out slow and gradually increase. If you start out too heavy, you will gas your fish.
