It's suprising looking around various forums that there is still no concrete answer with regards to why this stuff forms and what prevents it from reoccuring. Somebody says one thing, somebody else chimes in with something that rules it out...
It's pretty common knowledge, though, that putting Excel or Hydrogen Peroxide directly on it will kill it (so would salt, brake fluid, kerosene, all sorts of things!!).
Some of the various causes and (my thoughts) on the ruling out factor in brackets...
- Low CO2 (plenty of non-CO2 tanks don't have BBA)
- Unstable CO2 (unstable CO2 would cause poor plant growth; plenty of examples of good growth + BBA though)
- High CO2 (yes I've even seen this one which made me laugh; nah)
- Low Flow (plenty of us have reported, including myself, seeing BBA growing directly in the high velocity flow of filter returns etc)
- High Flow (plenty of us have reported it growing in quiet, low flow corners of the tank too!)
- Too much light (growing in my 100G right now, only a couple of T8's over the top; even growing down low where not much light penetrates)
- Too little light (also reported being found at the top of peices of driftwood etc up high being "gunned" with light)
- High organics (too many reports of users dilligently cleaning their tanks, performing massive daily WC's, yet still having this stuff grow)
- Dying plant leaves (grows on plastic pipes, rocks and even the aquarium glass too)
....so what's left??? Nothing as far as I can see???
Personally, my tank is doing pretty well these days. If only I could get rid of all the little bits of BBA that keep popping up I would say I've pretty much nailed it.
Bugger off BBA!
I remembered back to when I first started battling this stuff, I tried some of the "BBA magic" stuff. It did kill it off to some extend, but, from memory, I had to be very precise with the dosing because it was using copper as the effective ingredient. It got me thinking that perhaps, because of all our various fertiliser over-the-counter, DIY mixes, and the obvious variability in all them, that perhaps some of us are running slightly higher copper (or something else??) which might explain why some have no problem whereas others don't?
Maybe, and I'm not joking, it comes down to, not something *in* the water, but something *not in* the water?
Scott.
Bugger off BBA!
Scott.
