Hello,
I need to automate my process here and want to move to auto dosing. Here are the current stats on my tank:
350 gallon including sump
medium light
Co2 injection, homemade reactor 2' X 6" fed by a NW pump on timer runs 1 hour before lights and off
35 watt UV
ph is 6.7 daytime, 7.9 at night
KH is 5, GH is 112
pretty good fish bio load, medium plant density
I am dosing the following dry ferts daily/weekly as indicated
Micros ¾ tsp micros daily
Kno3 1 tsp daily, was 2 but my N03 went to hight so lowered it
KH2P04 ¾ tsp daily
K2S04 4 tsp weekly after WC
Seachem Iron
I am moving from a manual 10% WC dailey to a continous drip WC at roughly 10% daily as well, also include my 50% weekly with plant trim and cleanup
Not sure when going to auto dosing if I should continue with daily amounts or go larger weekly, does it matter?
I would like to extend this to make it last a month before having to refill. I was thinking of suing the Vertex 2.5L Libra dosing canisters, not sure I can get the required amounts of ferts and monthly duration from a vessel this size?
I believe if I make my mix more concentrated I can dose smaller amounts/
I am planning on buying the BRS dosing pumps, BRS 2 Part Doser – 1.1 mL per minute
I am thinking 2 vessel's? One for Micros and one for Macros? Can I mix my liquid or dry iron with either of these?
So how do I go about converting my dry volumes and frequency to liquid volume and frequency?
I hope I provided enough info to get some good direction moving forward.
Thanks!
John
medium light
35 watt UV
KH is 5, GH is 112
KH2P04 ¾ tsp daily
Seachem Iron
Thanks!
John
