Hi all and greetings from "down under" ....
This is my first post after joining a week or so ago on the recommendation from a fellow aussie over at TPT .... i have had a look around , tried to understand as much as i can and even had a play with the dosing calculators ...... but to be honest, i find it all a bit overwhelming ....
but i guess that's why i'm here... to learn a little ... so that it's not so confusing .....
here's a little background to my tank ...
My water here is very soft ... 24 hrs after taking it straight out of the tap it shows as pH = 8.1, GH = 5, KH = 3, .... in the tank my iron, phosphates, nitrites, nitrates, etc all usually test as zero, even on the occassional times that i let the water changes go a little ... altho i usually do a 50% water change each sunday evening most weeks .....
recently i started adding a little GH/KH + ... mainly because my test kit said that for better plant growth GH should be btwn 5-20 and KH btwn 5-15 ...this has increased GH = 10, KH = 8, and decreased pH = 7.2 ( i have also increased the bubble count over the last 2 weeks to increase CO2 ) ... however, i think that perhaps GH and KH are now a bit too high ... and i still need to get pH down a little and CO2 up a little ... again, some advice on this would be appreciated ...
my lights are normally on from 7.30am to 9.30am : noon to 4pm : and then 6pm to 10.30pm ( the "broken" periods are because i read somewhere once that it helped reduce algae outbreaks... but now i'm not sure that this is actually correct ... and that i might be better to leave the lights on for a continuous 10 or 12 x hour periond ... any comments on this would be appreciated)
... my plants seem quite robust and all absolutely pearl like crazy when i do a water change ..... generally when the lights are on there is also a constant stream of bubbles from most of them ...
while i am not very happy with my aquascape ... it's more a random hotch potch that just " happened" ... i have a multitude of plants whose id is not known to me... i think some are crypts (wendii and rubins ?) .......i have lots of tall vals in the back that grow like crazy, some spiral val on the side, lots of "baby" amazon swords that are a 6+ months old - they were cuttings from a big one - they never really seem to grow much - but otherwise seem very healthy and robust ... the rest i don't really know .... the tank looks alright ... tall clumps of val at the back and side - the rest is very short and flat ... but to me it looks very one dimensional .... and even tho' i don't really like it ... i don't want to change it at this stage until i learn more about the dosing regime ... i pretty much keep the tank reasonably clean most of the time ... so algae is present .. but not a huge problem ...
... i have never really dosed my plants on a regular basis at all .... just very occassional (maybe once or twice a month) ...doses of jbl ferropol and flourish comprehensive.....
i would really appreciate it if someone with experience could check my calcs on dosing etc to make sure that i have done it right before i start chucking all this stuff in my tank! ....
i have the following commercial products that i can use ... JBL Ferropol, and from the Seachem range i have the Flourish Potassium, Excel, and Comprehensive Plant Supplement ...
i have also been able to source the following products, Potassium Nitrate (KNO3), Mono Potassium Phosphate (MKPO4 ? ), Potassium Sulphate (K2SO4 - Sulphate of Potash), Magnesium Sulphate (MgSO4 ? ), Chelated Iron (Fe as Iron sodium 12% ethylene diamine tetra acetic acid) ... i really would prefer to learn how to dose dry using the "raw" ferts if possible ...
i have been unable to track down the plantex that seems to be so available in the USA ... but i do have a product called Yates Trace Elements ... it contains the following ...
K as Potassium Sulphate 22%
Mg as Magnesium sulphate 2%
Fe as Ferrous Sulphate 1%
Manganese as Manganese Sulphate 1%
Cu as Copper Sulphate 0.8%
Zn as zinc Sulphate 0.8%
B as Borax 0.2%
Molybdenum as Sodium Molybdate 0.1%
Sulphur as Sulphates 13%
i would also really appreciate any comments on how this product compares to the USA ones that most folk use ... is it ok?
and finally! ... here is what i think that i should be dosing! NB: t = Teaspoon
Sunday post water change:
Magnesium @ 3/4 t, Calcium Chloride @ 1/2 t...
THEN --
Sun,Tues, Thurs:
Nitrate @ 1/2 t, Phosphate @ 1/8 t...
Mon,Wed,Frid:
Traces @ 1/8 t
Any changes, suggestions, help, comments of this is greatly appreciated ... am i on the right track ... or have i totally stuffed up ....
... i am sorry that as my first post this is so long ... but i really do want to learn and it all seems to interlock together ...one bit seems to interact and affect another! .. maybe that's why it's so frustrating at times ... but then so rewarding when the tank hits that sweetspot!
thanks to those that take the time to read all this ... and even more to those that are able to answer one or two ... or all.... of the points raised
i look forward to my time here ....
Regards to all
aussietanker
B as Borax 0.2%
THEN --
Sun,Tues, Thurs:
Mon,Wed,Frid:
Traces @ 1/8 t
Regards to all
aussietanker
