Yellow Gas Pipe Thread Tape
Darkblade48
Dec 16, 2009
147
I was under the impression that yellow teflon tape is double density teflon and is just colour coded for gas lines.
It seems that it is generally used on larger NPT threads; for our purposes, I think single density teflon is fine, as long as it is applied properly.
thegasman
Subscriber
Aug 25, 2012
252
49
Anthem, AZ
I use the yellow along with "pipe dope" that is rated for gas use. Most likely overkill, but I never get leaks. I also trim the excess tape after the conmection is made. This makes for a neater finished product.
kevmo911
Oct 19, 2010
67
44
Greensboro, NC
The difference is simply the thickness, as you noted. But that difference can be compensated for by extra loops of the white stuff, and I'd much rather have some excess white tape sticking out, than yellow.
Matt F.
2,319
California
No need for anything more than regular teflon tape or Oates. Haven't had a leak in any of my builds for years. It all comes down to personal preference and what you have available. Neither one is better or will seal more. They are the same. They won't blow out, etc. Nothing to worry about.
One thing to consider is that gas pipe has much larger threads than our little 1/8 and 1/4" npt fittings. The gas-line dope might be coarser and thicker, which could cause leaks because you would be prevented from tightening the NPT fittings as much as you normally would with the regular stuff...
Food for thought. Thicker isn't always better.
