Would someone care to humer me!!
Gbark
Jun 15, 2009
266
Could someone please provide the ppm levels of ferts to add daily.
E.g.
KNO3 - Nitrate = 5.58ppm
KNO3 - Potassium = ?
etc :)
Philosophos
1,346
I'm not completely sure what you're asking. Do you want daily quantities of fertilizers to use? Raw ppm's per day?
If you dose 20ppm NO3 from KNO3 a week and about 2-5ppm of PO4 of KH2PO4, you'll end up with about 14-18ppm of K+ last I checked. I add my macros 3 days a week, micros the other 3 on alternating days.
Clear As The Mississippi
E.g.
etc :)
I am also not clear to me but if Dan’s answer is not what you are looking for… :confused:
In Potassium nitrate, the Potassium makes up about 37% and the nitrate about 63%.
If you are getting about 5.58-ppm Nitrate, from Potassium nitrate, you should have about 3.51-ppm Potassium.
I hope it helps.
Perhaps if you explained what you are trying to accomplish, we could better help you. :)
Gbark
Jun 15, 2009
266
I think what i am trying to say is, we always talk about adding 1/4 teaspoon of such a such, and 1/8th of the other etc.
What ever your tank size the daily dose of each should be:
KNO3
Nitrate = 5.58ppm
Potassium = 3.58ppm
KH2PO4
Potassium = 0.57ppm
Phosphate = 1.38ppm
CO2
25-30ppm
MgSO4
Magnessium = 1ppm
Philosophos
1,346
If you got those numbers from fertilator, odds are they're accurate.
I could do all the calculations for you, or I could just show you how based on the math I used when I started out so that you can do it any time you like:
KH2PO4:
Potassium: 39.09831 x1 = 39.09831
Hydrogen: 1.00794 x2 = 2.01588
Phosphorus: 30.9737622 x1 = 30.9737622
Oxygen: 15.99943 x4 = 63.99772
Total Molar Mass of KH2PO4: 136.0856722
PO4:
Total Molar Mass of PO4: 94.9714822g/mol
For 2 ppm of PO4 in KH2PO4:
136.0856722/94.9714822*2 = 2.865821803505558ppm KH2PO4
From there if you want to know the K+ in that dose:
K+ = 39.09831
39.09831/136.0856722*2.865821803505558 = 0.8233694809071854ppm of K+
Keep in mind that I wrote this all before I bothered to round anything. You can always shave this down to a more reasonable number of decimals if it's easier to look at.
Gbark
Jun 15, 2009
266
I got these figures based on what i dose, haven't heard of fertilator sorry :eek:
Not Too Out-Of-Whack
Over a seven day dosing cycle I would think them high, not outrageous but certainly the kind of numbers that if I suggested would have people jumping on me as a “Nutrient Type.” :p
Nitrates of 39-ppm are high side, I run that level plus a little in heavily planted tanks (with critters, 65-ppm non-critter). :)
Potassium of 29-ppm high in line with what I run with my Tiger Lotus’ (Loti?), but higher than generally necessary. ;)
Phosphates of ~10-ppm are high unless I am treating GSA or something, nothing terrible. :rolleyes:
Magnesium of 7-ppm is a little high for most folks run half that, no big deal, I tend to be in that range. :)
Nothing looks too out-of-whack to me, but then I am the utterly detested “Nutrient Type” your Mother warned you about. :eek:
I am still curious as to how we are supposed to be humoring you for (about?). Seems more like a statement.
I do not mind humoring you. :cool:
Two significant digits are sufficient.
The Fertilator is at APC http://www.aquaticplantcentral.com/
Tug
1,150
Washington, DC
Give them the 411
HI Gbark,
On another post your actual amounts of N and PO4 were much higher then you thought.
Gbark;47994 said:
Im so MAD with myself i could swear!!!!!!!
I thought i had this EI stuff sorted.
Might I suggest you share the tangible amount (tsp, Grams, ML) of fertilizer you add to X amount of water. Then let these guys check your math. You say your adding this or that in ppm but we have no way of knowing other then your word. How did you come up with 5.58ppm NO3?
Gbark
Jun 15, 2009
266
Tug;48000 said:
HI Gbark,
On another post your actual amounts of N and PO4 were much higher then you thought. Might I suggest you share the tangible amount (tsp, Grams, ML) of fertilizer you add to X amount of water. Then let these guys check your math. You say your adding this or that in ppm but we have no way of knowing other then your word. How did you come up with 5.58ppm NO3?
I took the amount of KNO3 to be added as EI for a 20-40 gallon, that is 1/4 tsp 3x a week.
so that is 1.25 tsp a week
I put that in into chucks calculator for my tank 33 gallon
that made ~37ppm a week
divide that by 7
5.28ppm daily dose of NO3
I read on another forum that the weekly amount should be 20ppm week
Tug
1,150
Washington, DC
Typical uptake rates of NO3, at high light and CO2 levels are 1-4ppm per day. PO4 0.2-0.6ppm. per day. I tend to dose 3.9ppm of NO3 every day. It depends on your biomass, lighting, CO2, etc. Dosing more (37ppm/7) is not a problem. If I dose less then 24ppm/6, I start to see some N deficiencies. My goal has been to try and keep the levels of NO3 around 5-10ppm on average after factoring in plant uptake and water changes.
Reference:
The Estimative Index of Dosing, or No Need for Test Kits
http://www.barrreport.com/showthrea...Dosing-or-No-Need-for-Test-Kits?p=217#post217
old version from 1996-1997 of list of levels and parameters
http://www.barrreport.com/showthrea...om-1996-1997-of-list-of-levels-and-parameters
A List of Recommended Levels and Parameters
By Tom Barr
http://sfbaaps.org/articles/barr_02.html
Wet's Stuff Calculator
http://wet.biggiantnerds.com/ei/con_v_time.pl
Gbark
Jun 15, 2009
266
I understand that EI is adding more than enough ferts so that the plants are never without.
And i know that if i follow the suggested routines laid out by TOM that i can't go far wrong.
And i know its not an exact science.
Here is the BUT :D
If the MAX Weekly uptakes are as follows:
28ppm NO3
4.2ppm PO4
28ppm K
Tom suggests that you dose as follows for a 10-20 Gallon Tank
+/- 1/8 tsp KNO3 (N) 3x a week
+/- 1/32 tsp KH2PO4 (P) 3x a week
+/- 1/4 tsp GH booster once a week(water change only)
+/- 1/32 tsp (2ml) Trace Elements 3x a week
50% weekly water change
So lets take the 1/8 tsp KNO3 added to a 10 Gallon tank that will add 12.15ppm of NO3 3x week.
Now if you add 1/8 tsp KNO3 to a 20 Gallon tank you would only be adding 6.07ppm NO3 3xweek.
As you can see it is recommended that the larger tank should require a leaner dose than the smaller one.
So thats why i wanted the ppm's as this can be expressed to any size tank.
I also noticed that TOM suggested a EI solution mix for a 20 Gallon tank as follows:
60g KNO3
10g KH2PO4
25g GH Booster
mix to 1000 DI water and add 5ml daily
this would give a weekly NO3 of 17.01ppm thats less than recommended when dry dosing.
So as its not an exact science,
Should we just aim to exceed the Max daily uptakes therefore looking for weekly ppm's in the region of:
to be added either by making solutions or dry dosing:
NO3 30-35ppm
PO4 11ppm (high due to the need of the k in the KH2PO4)
k 30ppm
Left C
Sep 26, 2005
2,500
71
Burlington, NC
Have you seen the downloadable Nutri-Calc .exe calculator in quenton's signature? It is called: "Nutri-Calc[v1.9.3 Mar 10/07]: an EI Dosing Calculator & Tank Size Calc" Using your 10g and 20g examples, lets say that your 20g aquarium has 17g of water in it and you want to know the EI amounts to dose based on 17g, it would give it to you. There are quite a few posts about this calculator that tells all the different things that it will do. It is really a neat fert calculator. You can use the nutri-calculator to calculate your dosing régime. Then use APC's fertilator that Biollante mentioned to calculate how many ppm's that dose is. Then you can use Chuck's fert calculator to make your solutions, if you want liquid ferts, that is. Using all three calculators, will clear up a lot of mud that is in that ol' Mississippi.
Tug
1,150
Washington, DC
Too bad my apple wont work with that download. I think this is a great little calculator, "Yet Another Nutrient Calculator". It is one lean, mean calculating machine.
For the smaller 10 gallon tank it is often recommend that people dose only twice a week.
Stick to the recommended dose of KH2PO4 (2-3 times a week). I wouldn't add more KH2PO4 then is called for just to increase the amount of K+. This thread explains why, http://www.barrreport.com/showthread.php/7404-Calling-Chemistry-and-Math-Pros?p=52131#post52131
Add GH booster and that adds K+, or add a little K2SO4, about 3-4ppm a week.
Where is our other lean, mean calculating machine? I haven't heard from him anywhere for some time now.
nipat
May 23, 2009
665
60g KNO3
10g KH2PO4
25g GH Booster
NO3 30-35ppm
k 30ppm
I would take EI as estimative.
Since the amount of plants in a tank is also a factor.
I read now a day, Tom adds 15 PPM of NO3 3x a week.
http://www.barrreport.com/showthrea...-Zoetermeer-The-Netherlands?p=53300#post53300
If you want to know your tank's exact uptake, I think you
may have to use test kits, may be once a few months, to check the trend.
