Would an RO/DI filtration system be beneficial?
Discussion in 'General Plant Topics' started by ShadowMac, Aug 30, 2013.
  1. ShadowMac
    ShadowMac Lifetime Members
    Mar 25, 2010
    1,043
    12
    1:54 PM
    I am wondering if an RO/DI water filtration and storage system for water changes would be beneficial for my aquariums.
    2011 water report shows avg pH of 9.0; Total alkalinity 86 mg/L CaCO3 (4.8 KH; but check my math) Total Hardness 180 mg/L (10.1 GH). Ca 43.4 ppm and Mg 9.1 ppm.
    Some guidance would be appreciated. If not necessary I will only use a carbon block filter and tap water for water changes.
    #1 ShadowMac, Aug 30, 2013
  2. AaronT
    AaronT Member
    Jul 29, 2013
    195
    1:54 PM
    Your tap water might be a bit hard for some more difficult species that like soft water. If you do decide to get an RO system you could simply do 50/50 RO and Tap changes and your parameters would be ideal for most any plant.
    Are you trying to grow soft water species like Eriocaulon, Syngonanthus or Toninas? Do you keep soft water fish? Don't forget the fish might like it too. :D
  3. ShadowMac
    Mar 25, 2010
    1,043
    12
    1:54 PM
    Hi Aaron, thanks for the response.
    I've just noticed some plants that do well and others that don't do was well as they should. I thought it might be due to my harder water conditions and thought an RO system couldn't hurt. I have space to store the water now and already have some logistical challenges to running water changes in the new home. For example the water access I want to use only has cold water, so I would have to heat it before hand. Might as well RO filter it, too.
    I don't have specific plans to grow soft water plants. I like to keep mostly softwater fish like apistos and other South American cichlids. Many of the schoolers I tend to choose are tetras or rasboras. I also keep some dwarf shrimp. I tried crystal reds before and they didn't make it.
    The next challenge will be finding an appropriate container to store it and a pump that can send the water up one flight of stairs (probably 60ft total). What is the best material to store RO water? Any suggestions on a pump that can do the work? I have a diagram drawn of what I would like to do.
    #3 ShadowMac, Aug 31, 2013
  4. TheLivingWater
    TheLivingWater New Member
    Jun 10, 2019
    8:54 AM
    I would highly recommend an RO filter... especially if you plan on keeping soft-water plants and fish.... Lord only knows what’s all in tap water these days, and you can re-mineralize (GH, Kh) the water to whatever parameters you want, Besides deciding to run compressed Co2 , the purchase of my RO unit is by far the best purchase I’ve made for my hobby...KoolermaxAr122 ...made in the us and reasonably priced
  5. Gabe Hayes
    Gabe Hayes New Member
    Jul 10, 2019
    5:54 AM
    I use a portable system I got off amazon called the AquaFX barracuda.
  6. Gabe Hayes
    Jul 10, 2019
    5:54 AM
    Here's a picture of how I have it setup. Seems silly but it actually works the best for me.
    [​IMG]
    iceburg and Phishless like this.
  7. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,116
    969
    8:54 AM
    I have been doing the same in the bath/shower.
    About every 3 weeks, but I fill Brute cans on wheels.
    iceburg and Gabe Hayes like this.
  8. EdWiser
    EdWiser New Member
    Apr 16, 2018
    23
    7:54 AM
    I have mine set up like this right now. With a 20 gallon brute trash can in the tub. It’s as easy way to do it and if you forget to turn it off at least it doesn’t flood the house.
    Gabe Hayes likes this.
  9. Michael Brock
    Michael Brock New Member
    May 26, 2019
    8:54 AM
    I have mine set up in our laundry room which is right next to the garage. I have the out line going through the wall to a Brute trash can in the garage with a float valve. It fills to the top, triggers the valve and stops. When I take water out it automatically refills. No hassle as long as you have the room for it.
