Hello everyone:
In planning and set up stages of 90gallon planted. A few months ago I puchased several 9L bags of ADA Aquasoil Amazonia.
Few days ago I set up a 20gal with AS; just water and substrate w/filter running. 20gal will serve as transitional/Q-tank. 90gal is still waiting to be set up. 20gal tank was at first clear, then cloudy within 12hrs. I let tank run an additional 12hrs to give a chance to clear up. It didn't so I did 100% water change, let run for 24hrs, tank is now cloudy again. Water was very slowly installed in tank in bowl & plate so as not to disturb substrate.
Water was clear initially - but clouded up afterward (a very light but noticeable tea color).
For the 90gal tank I earlier purchased Flourite. I had read Tom's and others support of AS. This 90gal is my first serious planted tank and I wanted to put the cards in my favor, so I decided to bite the bullet and purchase AS. So, I now have *both* AS and Flourite sufficient to substrate the 90gal. Tom's recent post of his AS cloudy issues, in addition to the same report of others now has me a bit freaked out given the 20gal newly installed with AS is cloudy.
Sorry to be such a blank slate but 'what should I do?'. It would be a disaster given my limited experience to later set up the 90gal with AS then have to tear the whole thing down. But perhaps my concern is too premature. I will continue to do a few more 100% water changes and will probably put carbon in the filter to see if that helps.
I would welcome any suggestions or experience. By the way, I added Tourmaline BC to the bottom of the 20gal, but no powersand and nothing else. 20gal is still empty except for substrate and water, filter running.
growitnow
growitnow
