Hello,
I've been trying to get my co2 delivery stabilized since setting up a new 5 lb canister with Taprite regulator/ solenoid. I'm having some difficulty getting a good flow of fine bubbles through the ceramic diffuser. I have to crank the needle valve wide open & set the working pressure to 30 psi just to get a decent flow. Is it me , or the diffuser? I should mention that prior to obtaining this 5 lb tank I was using the Fluval 88 c02 canister for the past 8 months. It worked perfectly(better than the big boy) except for the cost of $ 20.00 per canister which lasted 5 days ! I know it takes some tweaking, but at this rate I will probably burn through a 5 lb in a month ! Here's what the diffuser looks like. Thanks [emoji4]
Sent from my SM-G935W8 using Tapatalk
