Hello all,
I was wondering if you all could share your opinions about my new DIY external CO2 reactor. I plan to run this on the output of my Eheim Pro3 2071 (250gph) and then through an Hydor external heater and then up to my spraybar. I also have a Korilla Nano on order to help with flow inside the tank. By the way the tank is 33 gallons (25"x18"x18")
I found a similar design for a reactor on the APC forums from a few years back and thought I would try to copy that design.
I am probably being too paranoid about leaks, but I wanted to put a check-valve before the Co2 line so that in case that little tubing was to ever come off, then no water would leak out of the reactor. I obviously wouldn't want any water to get to the regulator, but it was a larger concern to me that no water get out on the floor in the event of a catastrophe. So that black plastic part on the CO2 inlet is a check valve.
I also like the fact that this design has a way to purge air or co2 build up at the top of the reactor (that is what the red handle ball valve is for). I want to mount the reactor to the wall of my cabinet so I wasn't too thrilled about having to tip it upside down to get out trapped air when trying to prime the filter. Plus I want to keep the hoses as short as possible and if I needed to turn the reactor upside down when priming, then that would mean longer hoses would be needed.
Anyway.....do you all see any major flaws in this design?
It has 5/8 barbs connected to the Ehiem 16/22 tubing. That 5/8" goes down to 1" where the water and Co2 make first contact. And then the reactor tube is 2" diameter and 10" long and the entire thing is about 16" from barb to barb.
I really wanted to use plastic hose barbs instead of brass, but I can't find 5/8" plastic barbs anywhere (let alone 16mm to perfectly fit the Eheim tubing). If anybody can provide me a link where I can order them I would be MOST appreciative.
Thanks in advance for any input !
Bill321
Bill321
