Will this check valve work?
Discussion in 'CO2 Enrichment' started by Micah D, Dec 10, 2017.
  1. Micah D
    Micah D Junior Poster
    Sep 29, 2013
    14
    12:28 AM
    Hey was wondering if anyone can tell me if this check valve will work. It' a parker Part #: C200B. It has a cracking pressure of 5 psi. I know swagelok has a lower cracking pressure of 1/3 psi. Should this be any concern. The reason I ask, is I found a local company near me that sells a lot of fittings to build up my regulator setup. Also another thing I was wondering. I have a mini burkett solonoid 6011, that I cant found a marking indicating flow direction. Does it have a specific direction?
  2. rajkm
    rajkm Article Editor
    Sep 16, 2015
    677
    218
    12:28 AM
    5 PSI cracking pressure is fine.. just means you need that much pressure for gas to move thru.
    Burkert will a NPT written on it.. the flow goes TPM so in flow has to on the T end of it and out is on the N side.
  3. Micah D
    Sep 29, 2013
    14
    12:28 AM
    Thanks rajkm for your reply, very helpful.
Tags:
