Wild Plant Identifications Needed :) (many)
Discussion in 'General Plant Topics' started by DutchMuch, Jul 11, 2017.
  1. DutchMuch
    DutchMuch Junior Poster
    Mar 8, 2017
    1,033
    389
    1:20 PM
    I only have pictures to go by, the water where I got these from was fast moving; hard & alkaline, and also was most likely around 58F degrees to low 60F degree waters.. Thanks in advance for the help it is greatly appreciated.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. DutchMuch
    Mar 8, 2017
    1,033
    389
    1:20 PM
  3. DutchMuch
    Mar 8, 2017
    1,033
    389
    1:20 PM
  4. MarathonFish
    MarathonFish New Member
    Jul 5, 2017
    13
    8:20 AM
    Where about did you find these? Looks like Java moss
  5. DutchMuch
    Mar 8, 2017
    1,033
    389
    1:20 PM
    At Mirror Lake, doesn't look like java moss. I have java moss, but maybe its a temperature thing. This moss is a lot thicker feeling, and the "leaves" aren't as large. Java moss I have in the tank is, java moss.
  6. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    5:20 AM
    i'm betting since North America that its some type of fontinalis...
    The one below looks similar to umbrella moss
  7. snarkingturtle
    Jul 17, 2017
    124
    8:20 AM
    Mirror Lake in Vermont? The flat, tongue-like plant is some sort of thalose liverwort. I have found the same or similar species in Ontario growing on emergent rocks in a stream and around a seepage from an old limestone dam. It was strongly attached by fine brown hairs. I tried to grow it in my current tank (my 1st real planted tank, low tech learner/experimental). It grows but lost it's form and does not attach underwater. The attached image is one of two remaining fragments after several months. I was wondering if it work out better if dry started on a rock or log before being submerged.
    I've been looking at a lot of mosses myself but I'm a bit lost without a decent reference. I have learned that many mosses have different terrestrial and aquatic growth forms and these can be quite different (this can be seen at any shaded vernal pool in May/June vs July/August). Most ID resources will show the terrestrial form. Maybe put a sub set on some wet substrate in a tupperware and see what it ends up looking like.
  8. DutchMuch
    Mar 8, 2017
    1,033
    389
    1:20 PM
    Mirror Lake in Arkansas. If its fontanalis that would be neat.
  9. rajkm
    rajkm Article Editor
    Sep 16, 2015
    670
    216
    1:20 PM
    If it does not attach under water you might do is wrap it around a rock with net like one does with riccia.
  10. DutchMuch
    Mar 8, 2017
    1,033
    389
    1:20 PM
    it attaches underwater
