Why Ei Shows 7.5 Ppm No3
Discussion in 'General Plant Topics' started by yusuf saraç, Apr 18, 2018.
  1. yusuf saraç
    yusuf saraç New Member
    Dec 26, 2017
    5:48 AM
    In https://rotalabutterfly.com/nutrient-calculator.php
    When I try to calculate How much kno3 I'm going to add to my tank and when I select "Estimative index" as my target. It says "To reach your target of 7.5ppm NO3 you will need to add ..."
    In EI method isn't the N level needs to be arround 10 - 20 ppm ? Why it says 7.5 ppm ?
  2. Chad
    Chad Member
    Oct 3, 2017
    34
    6:48 PM
    Dose these levels 2-4 times a week for EI.
  3. khanzer22
    khanzer22 Junior Poster
    Mar 25, 2008
    41
    2:48 AM
    That 7.5 ppm you dose per day, multiply by 2-3 (# times to dose per week) will yield you within the range of 10 - 20 ppm EI dosing ..
