why all the extra chemicals?
ccLansman
Jan 22, 2008
375
Vista, Ca
If EI uses KNO3, KH2PO4 and Micros. What is the need for all these other types of fertalizers? Can anyone give me some info on each and why they may be used?
Calcium Carbonate
Calcium Carbonate (Fine) 1 lb. CaCO3
Calcium Chloride
Calcium Chloride 1 lb. CaCl2
Calcium Nitrate
Calcium Nitrate 1 lb. CaNO3
Calcium Sulfate
Calcium Sulfate 1 lb CaSO4
Iron Chelate 10%
Magnesium Sulfate
Magnesium Sulfate 1 lb. MgSO4
Mono Potassium Phosphate
Mono Potassium Phosphate 1 lb. KH2PO4
Potassium Nitrate
Potassium Nitrate 1 lb. KNO3
Potassium Sulfate
Potassium Sulfate 1 lb. K2SO4
tedr108
514
Los Angeles, CA
Re: Ca & Mg... Not all local waters are created equal, and many are low in Ca and/or Mg, which the plants need. Most micros do not have them, or perhaps not enough of them. I suppose also that in a non-CO2 tank with no water changes that your tank could use up the available Ca and Mg. There are probably other special reasons for CaCO3, CaCl2 and CaNO3 that I do not know.
Re: Iron chelate... Most micros have iron, but I guess some don't.
Re: Potassium sulfate (K2SO4)... If your fish load is fairly high, they create NO3 with their waste. Therefore, adding KNO3 may ramp up your NO3 too much. K2SO4 is a good way to get your K without adding more NO3 to your water. With EI, K2SO4 can be used as a substitute for KNO3, if your nitrates are already high enough.
