Which fixture for 5' long tank
Discussion in 'Lighting' started by makutaku, Nov 12, 2012.
  1. makutaku
    makutaku Junior Poster
    May 28, 2012
    24
    8:29 PM
    The tank is 60" x 24" x 20", rimless, about 125 gallon.
    I plan to suspend the fixture at least 12" above the tank and I'd like to have enough PAR to grow anything fast if I wanted to.
    My budget is about $600 and I am undecided between these two models:
    ATI 60 Inch 4x80W SunPower T5HO High-Output Fixture $480 (58.5"L x 9.4"W x 2.1"H)
    ATI 48 Inch 6x54W SunPower T5HO High-Output Fixture $530 (47.0"L x 13.4"W x 2.1"H)
    Which one would you recommend ? I am also open to other suggestions.
  2. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5,624
    8:29 PM
    How about the 48" ATI sunpower 8x39w if there is one? Better spread and will easily provide enough PAR. Will be a little less on the ends of course but still plenty to grow any carpet..
    I would most likely go for the wider fixture personally. I think at your suggested height you will be fine with a 48" model....
  3. makutaku
    May 28, 2012
    24
    8:29 PM
    Thanks Gerryd! They do have 48" with 8 bulbs.
    Actually, If I yield to the temptation of more PAR, I am still undecided with the following two other choices:
    1) ATI 48 Inch 8x54W SunPower T5HO - $625 (47.0" x 17.4" x 2.1")
    2) ATI 60 Inch 6x80W SunPower T5HO - $600 (58.5" x 13.4" x 2.1")
    If I go with option 2, I get even more light and stay within budget. My concern, though, is how much light would leak from left and right. If there would be too much leaking then I would prefer option 1, your suggestion.
  4. Gerryd
    Sep 23, 2007
    5,624
    8:29 PM
    Perhaps this will help...
    I have a 72" x 36" x 20" lxwxh 220 gal tank powered by TWIN 36" 8x39w ATI. For 2-3 months one of them was in the shop and I simply centered the single unit. So, this means that there were 18" at the ends that were uncovered by the fixture.
    Yet, using 90% power I was able to grow anything in these areas, albeit more slowly due to lower PAR.
    Again using two units, I am at 45% max power....
  5. shoggoth43
    shoggoth43 Lifetime Charter Member
    Jan 15, 2009
    10
    8:29 PM
    I use one of the Tek 4' models. I'm pretty much using only the two furthest bulbs on it. 4 x 54 is a bit overkill and I need to work on getting my solenoid fixed. That said, I'm not having too much trouble growing stuff. Admittedly if I bothered to keep up on maintenance and everything else I'd be doing a lot better but I don't think any of my issues are for lack of light. With all 4 bulbs on I can grow algae like nobody's business, plus the other plants grow too. ;)
