Hi guys
I installed my new regulator this week and everything is running smoothly, nice and constant bps etc. However, I do have one problem: I can only inject CO2 in the tank when the bps is very high (e.g. 20bps). When it's only 2bps, nothing happens. I've tested the reg and needle valve with soap and everything is OK, so is the inline atomizer. I did notice a tiny crack in the "nut" of the atomizer that keeps the hose on it's place but this crack is so small (you can hardly notice it) that it should still keep everything in place. I'm using CO2 proob tubing.
I assume this is caused by a leak somewhere at the end of the system since my regulator works perfectly? Or am I doing something wrong? I've tested several PSI ranges (15, 20, 30, 40) but no changes. Anybody any idea what I should do?
