Hi guys,
Just refreshing my memory, a good needle valve -
1. Has metal valve seats, rather than plastic (less likely to shift settings due to ambient temp changes)
2. Is made of a higher grade of metal than cheaper alternatives (lower coefficient of thermal expansion)
3. Has a finer thread
4. Provides better knob resistance contributing to holding setting
Would I be correct in assuming that the popular Fabco, Swagelok and Ideal valves have all 4 of these qualities (whereas my current ebay needle valve doesn't) ?
That said, why would the Ideal be better than the much cheaper Fabco?
Also, before I forget, are all the popular specs of these brands good for both low and high bubble rates?
For example, could I use the Fabco successfully in both a 1 bubble per second and an uncountable bubbles per second scenario?
In my case, my bubble rate is currently so fast it's impossible to count on my 100g.
Scott.
Scott.
