What kind of light do I have?
Discussion in 'Lighting' started by gorazdr, Aug 23, 2014.
  1. gorazdr
    gorazdr New Member
    Aug 21, 2014
    12:09 AM
    Hello,
    I am starting new planted tank but I am not shure what kind of light to I have (low/medium/high).
    My tank is 240L (63 US gal.) and I have 2 54W T5HO bulbs 1" above water.
    Substrate is 45cm (17.7") from light in front and 38cm (15") in the back.
    I measured light intesity 45cm bellow lamp (no water) with lux meter and I get:
    - no reflectors: 1520 lux
    - 1 reflector: 3300 lux
    - 2 reflectors: 4700 lux
    I know lux does not equal PAR but bulbs are new 1 nature (4000) and 1 daylight (6800K).
    I wanted to go with low tech non co2 method, but I got confused the more I read.
    Hope someone can help me.
    Thanks, Gorazd
  2. Whiskey
    Whiskey Member
    Jun 14, 2010
    368
    12:09 AM
    I had 2 T5's above a 75G tank with individual reflectors and that was a bit too much light for low tech. With both reflectors off and an 8 hour photoperiod or so it probably would have been fine.
    I would start without the reflectors and see how it goes, then adjust from there.
    Whiskey
  3. gorazdr
    gorazdr New Member
    Aug 21, 2014
    12:09 AM
    Thanks, I will start without reflectors. What about photoperiod for start? Start with 8 hours or shorter?
    Gorazd
  4. Whiskey
    Whiskey Member
    Jun 14, 2010
    368
    12:09 AM
    8 Hours sounds like a good starting point, then you can adjust up or down from there.
    Whiskey
