What is the Most efficient R/O unit in the world today
Discussion in 'General Plant Topics' started by SwampGremlin, Aug 6, 2016.
  1. SwampGremlin
    SwampGremlin Member
    Jun 1, 2015
    271
    32
    1:58 PM
    As the title state i would like to get a high flow system that saves water as it would be more economical in the long run /
  2. Lakshmi Jagnnathan
    Lakshmi Jagnnathan Lifetime Member
    Jan 22, 2018
    42
    28
    5:58 AM
    Many folks run 2 membranes in series.....it will dramatically reduce waste....but you often need a pump with a series setup if you want a higher flow.
    I got a 250 gln per day system from filterdirect for about $250 bucks.....I can fill a 100gln container in about a day.....but my input pressure is only about 55psi.
    (due to pressure spikes, I put a pressure regulator for the incoming city water).
