What do I do?
Paul
169
49
Droitwich, UK
Currently I do a 50% water change every week, add KNO3, Seachem flourish and Seachem Iron twice a week. I need to add more phosphatres as well I think, do I buy phosphates to do the job or just change to Gregs pmdd mix? What do you think guys?
Greg Watson
5,023
United States
Re: What do I do?
I usually do not recommend PMDD Pre-Mix ... unless you absolutely can not get the various ingredients separately ... and since the Pre-Mix does not contain any phosphate in it which is what your goal appears to be ... the Pre-Mix most definately would not be appropriate ...
Greg
Wö£fëñxXx
65
61
Re: What do I do?
I would buy the KN03 KH2P04 and CSM+B and dose individually,
How long do you plan on using the Flourish? CSM+B is good stuff, alot cheaper the Seachem.
Avoid PMDD as Greg states, it's lacking and no control over what is being dosed as apposed to individual fert's.
Paul
169
49
Droitwich, UK
Re: What do I do?
Im going to use the Flourish till the bottle runs out, so it will be a while!! no point not using it now I have paid for it, she will only complain if I buy more stuff (she doesnt know how much the 2 petricolas cost yet ;) )
Ian H
265
Shipley, West Yorkshire, UK
Re: What do I do?
Paul, I think that you were having a phosphate problem at the start of the year weren't you? Some people are never satisfied. :)
BTW have you still got the Rowaphos in?
Ian
Paul
169
49
Droitwich, UK
Re: What do I do?
I binned the Rowaphos ages ago and planted it properly, seem to have it all under control now, just bits of brush algae on a few plants, thats about it now
Ian H
265
Re: What do I do?
I've got a little of the brush algae also, very persistant tenacious stuff it is for sure. I've just got a pair of SAE's and hope they take a liking to it as a snack.
Ian
775
Re: What do I do?
Paul, if the tap has good PO4 levels, like 1ppm or higher, then the water change doses the PO4.
Otherwise, add it. KH2PO4 works well and 450 grams will last a few years, decades.
Ian H
265
Re: What do I do?
At this point spare a thought to Greg W...............I mean decades before you get repeat business. :( How about putting a use by date on the chems Greg? :)
Ian
