What algea is this?
Discussion in 'Algae Control' started by BarnOwl, Jan 7, 2011.
  1. BarnOwl
    BarnOwl Junior Poster
    Jan 7, 2011
    5:30 AM
    Hi, my first post here and already an algea problem.... I posted this in several fora but nobody can give me an answer.
    Its a 200G tank. Ph controlled CO2: 6.9 Ph, 5Kh, NO3 20, PO4 1-2, 2x 70ml Profito.
    1 x 1700L/h, 1 x 4000L/h, powerhead Koralia 4 (6000L/h). 8 x 39w T5 dimmed with Profilux.
    I have been doing this for years and somehow this popped up half a year ago. I thought I had it under control but is is coming and going on the Staurogyne and Glosso and some on the Cyperus Helferi. Other plants are not affected.
    Anybody any thoughts?
    [​IMG]
    [​IMG]
    Jeroen
    Slideshow
    #1 BarnOwl, Jan 7, 2011
  2. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    5:30 AM
    To me it seems like you have both BBA and GSA. BBA is there because of a CO2 problem, GSA because of low PO4 (1 or 2 ppm is still low) also accompanied by low CO2.
    What I would do is:
    1. Increase CO2. Go down very gradually to a pH of 6,5 to 6,6. Wait a week after each change and watch what happens.
    2. Turn off CO2 at night. With high CO2 this could get dangerous to your livestock.
    3. Increase PO4 to at least 3 to 4.
    4. Less light. I don't know how much they are dimmed, mine (180 gallon) are at full power but it is just 250 Watts and no reflectors.
    I don't have BBA asa well as GSA.
    regards,
    dutchy
  3. BarnOwl
    Jan 7, 2011
    5:30 AM
    Thanks, Dutchy.
    I'll try that. Mind you, the light is dimmed. It's only at it's peak 1.5 hrs around 14.00.
    I have increased PO4 to 3 and put some more Profito in. I will increase CO2 from 6.9 to 6.6. I'll let you know!
  4. dutchy
    Jul 6, 2009
    5:30 AM
    The algae you have now is not going to disappear by itself. Watch if new growth stays algae free. Especially with GSA there is a delay of about two weeks before it stops growing.
    regards,
    dutchy
  5. BarnOwl
    Jan 7, 2011
    5:30 AM
    I know, I hope it stops. I'll come back to it in about two weeks..........
    I hope you're right about the algae, as you can see the black one sits on top of the green one. Strange......it almost looks like it is one species, as they both grow in the same spot.
    #5 BarnOwl, Jan 8, 2011
  6. barbarossa4122
    barbarossa4122 Guru Class Expert
    Dec 29, 2009
    975
    5:30 AM
    How about a few Ottos ?
  7. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5:30 AM
    Are you suggesting cause and effect here???? LOL
    I would suggest removing all algae infested leaves and stems. They are not going to get better, so why let them leach nh4 while they degrade? Plus, it will show any NEW algae more easily.
    dutchy and barabasa provided excellent advice that I would personally follow!
    Your plants look healthy otherwise from what I can see. More pics?
    What are you using for substrate?
    Remember that c02 varies greatly over time and space. Have you been increasing c02 and other ferts as the tank has matured and the plant bio-mass expands? It is very rarely set and forget is all I am saying.
    How about some full tank shots?
    How high are your lights from the water surface? You could most likely decrease light a bit and not affect your growth adversely. Lower light may help match the c02 now available with no other changes.
    All filters and such cleaned recently? An extra water change or two nevers hurts either when dealing with algae and to promote new/healthy plant growth.
    #7 Gerryd, Jan 8, 2011
  8. BarnOwl
    Jan 7, 2011
    5:30 AM
    Hehehe...never looked at it that way, but it's a good one! :D
    Yes, I am going to prune them out as much as possible. Today is Sunday (My refreshment and pruning day) so I will tackle it from there.
    Take a look at "slideshow" in my signature.
    Just fine sand from swimming pool filter, no substrate. I use fert balls for the plants that need it.
    The tubes are about 6 cm from the surface. Actually this is a problem that came up suddenly and has not gone away. I think I introduced it with putting new plants in.
    Thanks for thinking for a solution, Gerryd!
    @Barbarossa: I do have Otto's in there, and some more algae eaters.....
