Wet/Dry filter advice
Discussion in 'General Plant Topics' started by feh, Jul 15, 2011.
  1. feh
    feh Guru Class Expert
    Jan 14, 2011
    668
    11:39 PM
    I'm looking at the CPR CR1000 and CR900 wet/dry filters. The 900 is ( 20.5" x 10" x 15.5") roughly 14 gallons and the 1000 (20.5" x 12.25" x 15.25") is roughly 16 gallons after calculating tank volume based on their dimensions. Are these filters really big enough for a 75 gallon RR tank during a power failure? I'm guessing I'd need to expect to lose at least 2 inches of water when the pump is off... which I'm guessing would be around 7+ gallons. I just want to be prepared for the worst with this in mind. I do plan to drill siphon breaks in the return and drain plumbing as well as use a check valve on the return.
  2. feh
    Jan 14, 2011
    668
    11:39 PM
    It helps any I'm planning to use an Eheim 1262 pump for the return but that might change.
  3. Tom Barr
    18,660
    600
    11:39 PM
    I have a 900 for sale actually.
    I made a custom sump for the reef instead.
    It's plenty of filter.
  4. feh
    Jan 14, 2011
    668
    11:39 PM
    So I don't need a 30 gallon capacity for worst case scenario with the display tank draining? I know the amount of bio media and so forth is plenty, but I'm looking at what-ifs like if the check valve failed to close on the return and things like that. Which is why I was asking about the water capacity with them.
  5. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    11:39 PM
    If the check valves fail, you are in trouble regardless....
    Get a good one, ensure like you said you have siphon holes that will uncover quickly, and test shutting the system off several ways so you can see what happens for when you are not there...
    I think the sizes you mention will be fine. For reference I have the aqueon model 4 but I will have a bigger tank than you and I like it had 3 filter socks builtin. Plus a nice lid and a decent sump size.
  6. feh
    Jan 14, 2011
    668
    11:39 PM
    What brand check valve would you recommend?
  7. Tom Barr
    18,660
    600
    11:39 PM
    Eh?
    You drill a small anti siphon hole right at the max water surface height.
    No need for a return check valve.
    When the pump turns off........the siphon is automatically broken.
    The sump might fill up a gallon or two at most.
    Google "anti siphon hole aquarium return".
  8. feh
    Jan 14, 2011
    668
    11:39 PM
    Yeah, I do intend to drill the return and the drain for siphon breaks. So you're saying the check valve would be a waste?
  9. Tom Barr
    18,660
    600
    11:39 PM
    No need if the AS is there.
    That's the point, unless you have a bottom drilled tank without an overflow, but then it's just a check valve waiting to fail.
  10. feh
    Jan 14, 2011
    668
    11:39 PM
    True. I'm tempted to go with the Proflex model 2... if I ever decided to break it down and do a saltwater tank with it I wouldn't have to buy a sump. Just have to find a good skimmer, replace the bulbs, maybe a bigger pump, and some nice power heads.
  11. feh
    Jan 14, 2011
    668
    11:39 PM
    I've decided to go for the aqueon... its a little more but I really like the flexibility. Thanks for the advice. :)
  12. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    11:39 PM
  13. feh
    Jan 14, 2011
    668
    11:39 PM
    Yeah, I saw them. The wet/dry option requires you to buy a kit that comes with the bio tower parts and media. I like this one because of flexibility, plus the filter socks act as a prefilter before water hits the bio tower. The only thing I don't like is how small the bio kit is for the model 2. I haven't bought anything yet. So I still have some time to think on it.
