Well at Build my LED here would be the specs of a 18" one
Discussion in 'Lighting' started by reef12, Aug 9, 2013.
  1. reef12
    reef12 Member
    Apr 29, 2013
    534
    10:14 PM
    http://www.buildmyled.com/custom-report-details/?partNo=PS1890S101ABLADALBMAALAAL
    Don't know if that would go , this would be over a 44 Gallon hex.
    The LED's in the row are.
    6500K
    5700K
    450nm Royal Blue
    6500K
    4500K
    6500K
    450nm Royal Blue
    5700K
    470nm Blue
    6500K
    6500K
    450nm Royal Blue
    6500K
    6500K
    450nm Royal Blue
    Should any red be added the White's are Cool white the 6500K's and one at 4500 K is neutral white.
    The par at 6 '' under 6.5 loss 12 11.5 loss 24" 18.9 loss and at 36 " 24.4 loss.
    Here another run down.
    Estimated Electrical Watts
    19.3
    Radiometric Watts
    5.2
    Wall Plug Efficiency
    27%
    Lumens
    1103
    Lumens per Watt
    57
    CIE X-Coordinate
    0.242
    CIE Y-Coordinate
    0.197
    CCT
    N/A
    CRI
    N/A
    PPF (micromoles/sec)
    22.10
    PPF Efficacy (PPF/Watt)
    1.1
    Blue (400 – 499nm)
    51%
    Green (500 – 599nm)
    31%
    Red (600 – 699nm)
    17%
    Far Red (700 – 750nm)
    2%
    Any need to be increased?
    Jeff
