I have been using a pH adjuster (seachem acid buffer) with my tank for five months in order to make my water more accommodating to my EBR's and cardinal tetras. I have a couple questions regarding this kind of water treatment.
1) is it necessary to modify the water in this way? will fish adjust, particularly those types mentioned, to local water?
2)what are the best methods to adjust these parameters? I've seen buffers, ph downs, RO/DI water, peat, black water extracts, etc. I'm assuming RO water is ideal, but expensive and difficult to implement.
3) my buffer doesn't seem to hold and I believe its because it isn't overcoming the buffering capacity already in the water. It seems I would have to add large amounts and risk a pH crash at every water change. This doesn't seem like a good approach. Could my seiryu stones limit the pH buffer in regards to kH changes? Could the buffer be reducing pH and kH in the water, but the stones over time counteract that effect? the seachem buffer lowers kH and releases CO2.
Last night I did a water change and decided to skip the buffer since its effects do not appear to be lasting and I thought it may not be beneficial. I ended up losing one cardinal within 20 minutes of the water change and an EBR today. The EBR i lost had been in the tanks, happy and healthy for months during most of that time I was adding buffer. The new rams (in the tank for a week) didn't seem stressed at all. This was their first water change. I feel like I did something stupid by not adding the buffer and adding a Tetra Black water extract instead. I have a regular GBR in another tank that I don't buffer or add anything at all and he is just fine, same for another who I recently gave to a friend, no problems with them in water as is out of the tap. Am i overcomplicating this? Am I making adjustments that aren't necessary and playing too much with the chemistry of the water which can have more of a detrimental effect on fish than the actual water pH and hardness itself?
someone please help me out
I will test and post my tap parameters tonight ASAP.
thanks to all.
thanks to all.
