H
Htomassini
Tom in reading your posts, you advocate using tap water for tanks and you've also mentioned how you only use a carbon filter for the chlorine when doing your w/c. Here in Ft Lauderdale i started with tap but I used to have a lot of issues (not besides being rock hard at ph of 8.5+++) that I went with ro. The city has not issued a water analysis since 2009 and they burn the pipes with chloramine. The water here is also very yellow, our ice cubes are disgusting not to mention that if you have a white tub and you fill it to take a bath, it looks like someone peed in it.
So My question is two fold, how do you get rid of the ammonium from the chloramine? I know that the carbon filter will take care of the chlorine, do you still use prime or a like product for that? Also the ammonium is still in the water but no longer an irritant like ammonia, so how does it go away?
