I did some testing with my API test kits and found these readings. If someone could respond to the results that would be great. Not sure if a couple of the readings are out of whack or not, and if so, what the remedy is. I do not use R/O water and my tanks have been running for about 3 months now....
any help would be great.....thank you in advance.
GH over 214 ppm kh/gh (my chart does not go higher then this. I am a little concerned about this reading, not sure if this is normal.
KH about 6degrees or 107.4 ppm kg/gh
N03 about 10mg/l
NO2 0mg/l
ammonia 0mg/l
tds level 270ppm
ph is about 7.8 (little high but that is what comes out of the tap)
N03 about 10mg/l
NO2 0mg/l
ammonia 0mg/l
tds level 270ppm
