Water Change & Water Conditioner
Discussion in 'General Plant Topics' started by kizwan, Jun 16, 2020.
  1. kizwan
    kizwan Member
    Aug 17, 2019
    64
    3:07 AM
    Which method did you guys use when doing water change?
    1. Syphon the amount of water you want to remove out of the tank. Fill tap water in a bucket. Add water conditioner into it. Then add the treated water to tank.
    2. Syphon the amount of water you want to remove out of the tank. Add water conditioner into the tank according to the amount of water you need to add. Add new tap water into the tank.
    BTW, did you guys add water conditioner into the tank when you add new fish to help it acclimate? On the bottle of my water conditioner (Tension Gon) stated the amount of dosage to use when introducing new fish.
