If I plumb my filter installation as shown below will it work for draining the tank, refilling it, vacuuming the substrate, and topping off the water level? The water would come from the cold water plumbing, going through a regulator, throttle valve and filter. The drain would go to an open pipe where the water would be collected in 5 gallon buckets for watering container plants.
These valves would be under the tank, in the enclosed stand.
EDIT: Illustrations revised, old version that was here omitted.
