Re: Venturi Design
This adds a fine venturi mist once the capacity limits and stauration levels(O2) have been reached in the tank. It basically pruges the gas (namely O2) when you don't need it anymore. If you keep adding more CO2 beyond this, the burp hole will burp out gas bubbles.
So this is a self leveling device but also acts to disperse (O2) CO2 well in larger tanks like a very effective diffuser stone, this is better since it also has water movement added.
Other gases besides CO2 influence diffusion. Once these levels(O2) build up about 1/2 way through the day, the reactor's abilty to 100% diffuse CO2 is greatly reduced. Then the gas bubble increases and the venturi kicks into high gear, the O2 is expelled and the CO2 is still diffused, although not 100%, this is still a very good solution to "O2 pruging" of the gas chamber.
I designed this 10 years ago and to date no one has said about why the bubble builds and why the venturi helps. Some suggested CO2 saturation levels but that is not the case. We can measure that easily.
Most folks that own CO2 reactor see a gas build up during the photoperoid, this is also directed correlated and proportional with a rise in O2 levels.
O2, unlike CO2, does not dissolve as well in water, so we have a build up in the chamber. This adds the pure O2 to the tank as well while also pruging the unit of other gases besides CO2 and allowing it to continue adding just CO2.
So there's your answer and probably more.
