Vacuming sand substrate
jonny_ftm
Mar 5, 2009
821
It's the first time I use a sand substrate, the Flourite Black Sand. I noticed that it is impossible to vacume it like a gravel and no way to stir the substrate while you vacume it. Is this substrate a source for organics sedimentation and later problems?
Yes
Hi Jonny,
Yes, sand substrates need cleaning, in my always humble opinion. :eek:
I use a vacuum with a relatively larger opening and a body with a greater volume. This allows the sand to swirl and settle back down.
I tend to work slowly and do smaller percentage of the tank each time. I use a glass stirrer and a bamboo skewer (something with a little 'flex') to stir the sand and work up next to the edges while hovering the vacuum over the area being stirred.:)
I just squeeze the siphon tube to reduce the suction to reduce any sand from being sucked up.
jonny_ftm
Mar 5, 2009
821
Thank you both, I'll use the squeeze way, sounds practical. Eventually, I'll put sort of a tap on the tube to definately adapt the flow
