Using Seachem prime/safe as a preventative measure when rescaping
IUnknown
61
I've been having ammonia issues in my new tank. I don't know if its because it is still cycling, or I'm having issues with my flow rate/oxygen levels. Do people use Seachem prime/safe as a preventative measure when rescaping? So that when you disturb the substrate and then change out the water, the prime/safe deals with the remaining spike in ammonia.
I'm just wondering if my fiddling with my tank is causing my algae issues and maybe I should do everything I can to keep ammonia from spiking.
