B
Brian20
Guest
Hi, I was looking in the mosura line and I am interested in this products:
Mosura Old Sea Mud Powder
Description: Is a safe and natural product which enhances water quality, replenishes and enhances minerals and trace elements in your tank water that has been depleted, either by your local utilities, water changes or by excessive filteration, and remove certain harmful substance like decomposed organic carbon, amines and glysxerols from your water, itis also capable of removing heavy metals, free radicals and pesticides in the water.
Use of Old Sea Mud is very popular in Japan, and almost all pro shrimp keepers use them.
We select high quality mineral rock to be used in our breeding tank and that explains why Mosura Old Sea Mud Powder contains very high portion of trace element, that is close to 3% by weight and close to 70 different trace minerals and compounds have been identified, making it very suitable to remineralize your tank.
This product is used in our new tank setups as the lowest level of the gravel or regular adminstrations into water column. Mosura Old Sea Mud Powder is capable of polishing the water by attracting impurities in the water, your aquarium water get clearer after Mosura Old Sea Mud Powder is used in water column. For first time usage, the tank may take longer time to clear up, however, for subsequent usages, clear up time should reduce as an indication of improving water quality.
This product can not only improve the well mean of fauna and also improve the growth rate of of flora because of the concentration of trace elements in it.
We recommend to use this product:
during tank setup
dose it regular into your tank water column if you have not use it as a base
after 6 months dose it into water column if Mosura Old Sea Mud Powder has been used as a base
In summary, it has these functions:
Increasing good bacterial activities
Improving water quality by removing toxic such heavy metal and free radicals.
Deodorizing unwanted smells
Reducing the number of water changes
Re-mineralization of tank water for shrimp, fish and planted tanks.
Appears to be a excellent product for the planted tank, with or without fish, but, there is much truth in what it says?
MOSURA Mineral Plus
Description: improves the colour of Crystal Red Shrimps and Red Bee Shrimps, in particular it intensifies the whiteness of the shrimps. This is achieved by providing the essential minerals that are lacking in our tap water. By providing a conducive environment for the shrimps, it allows them to build up their exoskeletons, thereby allowing for stronger and more vibrant colouration.
Our tests have also shown this product to increase the intensity of blue in blue tiger shrimps and golden eyes shrimps.
This products does not alter the pH and kH of your water, but will mildly alter the tank's GH value. MOSURA Mineral Plus can be used on an existing tank, added to a new tank or after every water change.
This appears to be a GH booster with Micros. Nothing special for tanks I think.
I am intrigued by the first product. If it works like it says I maybe buy one even without shrimps.
during tank setup
MOSURA Mineral Plus
