Using Fertilizer Salts for Vegetable Garden
Squidly
82
Is there a calculator out there that you can use to prepare garden N-P-K and trace elements for vegetable garden use? One that allows you to target a range, say 15-15-15 etc. (in separate containers of course). Above my pay grade to figure it out!
Allwissend
Super Moderator
Moderator
929
396
63
www.intuitiveaqua.net
Before going into details, from an economic stand point it might not make a lot of sense to make your own with aquarium salts. Terrestrial plant fertilizers are rather cheap.
The Rotala calculator can be used for that purpose https://rotalabutterfly.com/nutrient-calculator.php .
Just put the volume of your fertilizer solution, instead of your aquarium volume; dry dosing and dose to reach a target.
15 on the fertilizer bottles stands for 15% which, for our purposes is the same as 150000 mg/L.
But, 15-15-15 is not N-P-K in most countries. If you look on the back P is actually given as P2O5 and K is actually given as K2O... so in actual NPK it would be 15-6.5-12.5. Thus to recreate a commercially labeled 15-15-15 your targets will be:
NO3: 664000 mg/l
PO4: 20000 mg/l
K: 125000 mg/l
Using KNO3 as your only source of N will push the K way over your target. Most terrestrial plant fertilizers have ammonia or urea as their main source of N. This goes back to the starting point... it may not be worth the bother.
Kukrai
Jan 28, 2025
Canada
Personally, I use this particular service to watch sex broadcasts, because this service - https://bongacams.com - can be used even for free! Also on this site and its service I found a lot of sexy women with big boobs who often conduct their porn broadcasts on this site. So try this service too! Bye.
There are a few online calculators for mixing fertilizers to hit target N-P-K ratios. Look for “fertilizer blend calculator” or check agricultural extension websites. If you need help with a specific mix, let me know!
Kukrai
Jan 28, 2025
Canada
NO3: 664000 mg/l
PO4: 20000 mg/l
K: 125000 mg/l
Hello. I can recommend you a very high quality and very cool website where you can start meeting nice people online. This site is https://www.nаstyhookups.com/granny-hookup.html . And that's why I want to recommend this site to you, because it is the best dating service! Good luck with your dating and relationship.
make sense
