Using a PH probe in a "drop checker"
Discussion in 'CO2 Enrichment' started by magicmagni, Mar 24, 2013.
  1. magicmagni
    magicmagni Prolific Poster
    May 15, 2005
    55
    3:02 AM
    I was thinking how a drop checker works and how it is a great way to measure Co2 because we measure the CO2 through a reference solution instead of the Aquarium water which may have fluctuating KH and or sources of carbonate that can throw off the PH/ KH relationship. The problem with drop checkers is that it gives you a ballpark idea of how much Co2 you have through subjective interpretation of the colors, also some PH chemicals may be a little different than others and etc.. I'm thinking that by replacing the PH chemical with a PH probe would we not get the best accuracy? Also the probe will last longer/ need less cleaning since it will be isolated from the Aquarium water.
    Anyone try anything like this before? Any thoughts?
  2. Darkblade48
    Darkblade48 Guru Class Expert
    Dec 16, 2009
    147
    3:02 AM
    This idea has been proposed before over at the Planted Tank; I am not sure what came out of it, if anything, but you may want to take a look over there yourself.
  3. UDGags
    Sep 13, 2009
    630
    37
    3:02 AM
    I base my co2 off a probe. I keep the probe in the sump all the time.
    Sent from my DROID BIONIC using Tapatalk 2
  4. magicmagni
    May 15, 2005
    55
    3:02 AM
    I may have to check that out. Thanks
