URGENT: Which light fixture is better?
Discussion in 'Lighting' started by mathman, Apr 4, 2011.
  1. mathman
    mathman Guru Class Expert
    Mar 8, 2011
    260
    12:21 AM
    Here's how the tank looks like with the Jalli 220W light fixture.
    The light fixture has 4 bulbs each 10,000K and 55W for a total of 220W. The fixture has two independent plugs allowing me to turn on 2 lights first and then the other two at a later time during the photoperiod.
    The other light fixture is made by Current USA and it has two bulbs each 54W and 10,000K for a total of 108W. Here's a picture.
    If you think the 220W is a better choice....do you recommend i use two timers to control each pair of lights...what is the best combination? Meaning how long would you have two bulbs on prior to the other two to come on?
    I am trying to grow: anubias, java ferns, tiger lotus, amazon swords, dwarf baby tears, crypts, and two stem plants which i forgot their names.
    thanx.
    PS let me know if you want more infor.
    #1 mathman, Apr 4, 2011
  2. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    5,624
    12:21 AM
    If your c02 and other elements are fine I see no reason why the PC fixture would not work with your stated goals....
    I would use two timers so you can have better control of the lighting....
  3. mathman
    Mar 8, 2011
    260
    12:21 AM
    Hi Gerry,
    I am currently using pressurized CO2 and dosing using the EI method. If I use two timers, what do you think about the time period for each pair of lights on the JALLI fixture?
  4. Gerryd
    Sep 23, 2007
    5,624
    12:21 AM
    I have my timing as follows:
    4:00 pm - c02 on
    4:30 pm - first bank of 4 lights on
    5:30 pm - second bank of 4 lights on
    10:30 pm - second bank OFF
    11:30 pm - c02 OFF
    12:00 midnight - first bank OFF
    This works for my schedule. It allows the c02 to build up a bit before all the lights are on fully and has a small ramp up/down cycle.
    Hope this helps.
  5. mathman
    Mar 8, 2011
    260
    12:21 AM
    Anyone else with an opinion? Thanx.
