Unknown Hygro* Species, Deficiency?
Discussion in 'General Plant Topics' started by SpiritualEngr, Sep 11, 2018.
  1. SpiritualEngr
    SpiritualEngr New Member
    Aug 27, 2018
    7:48 AM
    I'm a few weeks in to this new aquarium, 20 gallon long. Everything seems to be growing well. This plant was only labeled as "hygrophilla species" at my LFS. I noticed this morning that these leaves were looking a little strange.
    I have been dosing pps-pro, inject CO2, and did a 5 gallon water change on Sunday. I tested the hardness this morning.
    KH ~ 5, GH ~ 7, pH = 7.0
    This tank is home to a dozen or so Blue Dream Neocaridina, 6 otocinclus, and a few snails that came in on the plants.
    Sent from my LG-H931 using Tapatalk
  2. SpiritualEngr
    Aug 27, 2018
    7:48 AM
    Trying to post photo.[​IMG]
  3. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    498
    274
    2:48 PM
    Hi welcome to the forum.
    That is some variety of Hygrophilla corymbosa.
    Are the plants new? Some new plants have been grown out of the water and will allow older leaves to die when they are submerged. That is somewhat expected.
    If that is not the case, it looks like a nitrogen deficiency in old leaves, possibly also K and PO4. If you do PPS pro I suggest increasing your macronutrients dosing at least in the beginning or after a large waterchange. After a while the nutrients will accumulate at some level.
    SpiritualEngr and burr740 like this.
  4. SpiritualEngr
    Aug 27, 2018
    7:48 AM
    Thanks for the reply. They were bunched up and floating in the store tank. They have been in my tank for 2 weeks. I picked them a part and only kept the tops. I push the first full set of leaves/node into the sand and left the top set/node just above the sand. So the first rosette of leaves are old growth, the more upright looking are all new growth.
    I forgot to mention that my lighting is an older 65w PC. My thinking was the bulb is older and probably not as strong as it once was so I wasn't really considering it "high light".
    I noticed what may have been some BGA on my driftwood last night. I pulled it off and sucked it out with a turkey baster. Checked my NO3 and it was ~ 10 ppm, probably a little under. Looking back at recommended dosing I think I have been under dosing for my lighting. I have been doing 25-30% water changes weekly. So I doubled up my dosing this morning and will continue moving forward.
    One other thing I came across was calcium deficiency. I figured with my hardness this wouldn't be the case but it seems to be the first thing brought up with misshaped/deformed leaves. Any suggestions regarding that?
    Allwissend likes this.
  5. Allwissend
    Jun 20, 2016
    498
    274
    2:48 PM
    You are right, with a GH of 7 it is highly unlikely that there is low Ca in the water and there are many nutrients involved in correct leaf formation and signaling. That being said H. corymbosa is a very robust plant that likes nutrient rich waters and/or substrates. I think increasing the dosage for now is a good starting point. Let us know how it goes.
    SpiritualEngr likes this.
