Two month into EI: diatoms in my sump
Discussion in 'Estimative Index' started by fablau, Feb 27, 2014.
  1. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,787
    611
    5:57 PM
    Hello folks,
    Here is a question for you: I moved into EI about 2 months ago, and now I see a lot of diatoms build up inside my sump, mostly inside my sump first chamber (where the tank outflow is coming). I setup this tank 5 years ago, and this never happened before. Is that normal with EI?
  2. jerrybforl
    jerrybforl Lifetime Members
    Mar 7, 2010
    1,034
    1:57 AM
    Do you have any silicates in your tank/sump?
    Just do water changes every other day, and use some micron pads in your sump to help collect. Clean it very well. They will go away in time. Takes a few weeks, so don't do anything drastic!
    - - - Updated - - -
  3. Tom Barr
    18,678
    686
    1:57 AM
    do you have light in your sump? If not, that's not algae.
  4. fablau
    Sep 13, 2008
    2,787
    611
    5:57 PM
    No, I have not lights the sump is in the dark inside the tank cabinet. If not algae, what's that brown film that really looks like diatom?
  5. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    1:57 AM
    That's not diatoms. It's the nitrifying bacteria and archaea.
  6. fablau
    Sep 13, 2008
    2,787
    611
    5:57 PM
    I never had that stuff before moving into EI... But I have also increased the water flow into the sump at the same time. So, if they are bacteria, is that a good sign? Do you have the same "stuff" in your sumps as well?
  7. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    1:57 AM
    The increased flow will definitely increase the microbe colonies. I don't have a sump but I have it in the filter inlet and outlet pipes and tubes. It should also be colonizing your bio-media. Yes, it's a good sign.
  8. fablau
    Sep 13, 2008
    2,787
    611
    5:57 PM
    That sounds good then! I was really worried about it and was trying to find a way to get rid of it!
    Thank you for your help, appreciated.
  9. reef12
    reef12 Member
    Apr 29, 2013
    534
    1:57 AM
    Do you run just a sump?
    any other filtration in there?
    I do notice only when using CO 2 a brown stuff all over my filters I use canister types.
    Always been that way I say the CO2 adds to it, but hey plants are okay.
    So how the plants doing Fab?
    Good we hope.
    Jeff
  10. fablau
    Sep 13, 2008
    2,787
    611
    5:57 PM
    Hi Jeff! I have just a sump for my 75gl tank. Glad to know you have the same brown stuff I have now.
    Plants are doing good, Ambulias are getting better, but I am still struggling with Rotalas and Alternantheras. I will probably post a new thread about those plants soon.
    Thanks!
    Fab.
