Tsing's 135
Discussion in 'Journals' started by SingAlongWithTsing, Apr 6, 2017.
  1. SingAlongWithTsing
    SingAlongWithTsing Junior Poster
    Feb 17, 2016
    145
    154
    12:41 AM
    moved the windelov from the right side of the tank to the branches. dunno if i like it yet, kinda also worry about it getting 300-350 par up there.
    there's also 1 or 2 stems of hygro pinnatifida up there, gonna see how red it gets from high light. it might end up replacing the windelov on the branches if it gets that canopy effect
    [​IMG]
    right side now after mini rescape, the araguaia might come out for some other plant on
    [​IMG]
    nasea gold looking good, added hygrophila pinnatifida and barclaya longifolia
    [​IMG]
    micros were too high and made ar mini wavy, more experienced people confirmed this
    [​IMG]
    gonna go back to low micros:
    [​IMG]
    FTS:
    [​IMG]
    DutchMuch likes this.
  2. Dale Hazey
    Dale Hazey Junior Poster
    Feb 18, 2017
    165
    144
    8:41 AM
    Tank looks really good Tsing.
    Is operation moss wall still a go? That would be awesome.
    You got any top down pics from the surface?
    Dale
  3. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    thanks
    unfortunately project moss was has been delayed, haven't really decided what moss to go with. plus i might be re-plumbing the tank in the next few weeks, moving the outflow to the right corner and building some type of manifold for the return line and co2 to output.
    some top shots, need to figure out how to avoid the led glare
    side shots too
    that lil guppy might end up being moved to a different tank, dude keeps harassing the neon tetra for w/e reason
  4. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    re-did the sump on tuesday, reduced co2 degassing, reduced the chance of water by passing the bio-media with the pond box
    CO2 drop by the end of day @ 80 cc/min: 8.2 -> 6.6, before renovation 8.2 -> 6.8.
    Gonna reduce CO2 a lil bit, I don't think I need a 1.6 drop lmao. Gonna try to get the pH to drop to 7 with in 2 hrs of the reactor turning on.
    (click for larger images)
  5. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    August 23rd, 2017
    Ripped out a majority of the Bacopa Caroliniana on the left side
    Replaced it with a mix of Limnophila Hippuroides and Alternantherea Reineckii Varigated, emersed forms from PearlingPlants. Separated the grouping with Mermaid Weed from @burr740
    The Bacopa Caroliniana and Alternantherea Reineckii Varigated might swap places depending on how pink the Limnophila Hippuroides get.
    Hoping the Mermaid Weed turns a nice orange color in that area of the tank, should be close to 120 PAR at where it's planted.
    And yeah that's some plastic mesh on the wall. I might just use Monte Carlo, HC, or some type of Hydrocotyle for the wall after seeing this video
    Not sure sure what to with the Nesaea pedicellata Golden, kinda want to move it but it seems to like that spot in the tank
    the Lagenandra Meeboldii Red seems to like that spot too
    Upped Plantex CSM+B a lil bit due to a potential Mo deficiency with the Hygro Pinnatifda, added Fe Gluconate again in attempt to see if I can make the Ludwigia Perunesis a deep red like a few weeks ago
    Still tempted to roll my own micros, mostly because I'm pretty sure the Fe EDTA isn't doing much at my pH range. not being able to increase the other micros without increasing Fe EDTA is also a pita
    FTS
    #45 SingAlongWithTsing, Aug 23, 2017
  6. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    Switched to a recipe by burr740 about a month ago:
    I've added a bit more Fe gluconate to test some stuff. Might end up switching the extra Gluconate to DPTA
    AR Varigated is looking nice
    AR Mini is still recovering form all the bs I put it through but it's doign a lot better with with burr's trace mix
    No clue what this plant is but it grows stupid fast in my tank
    Same plant just in a shadier spot of the tank
    Favorite angle:
  7. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,290
    2:41 AM
    Side view looks sweet!
    You can speed things a long with the AR by going ahead and pinching all those older ratty leaves off. Be ruthless, it'll thank you.
  8. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    removed the bolbitis for now, kept getting bba on it and the driftwood, co2 and fert flow is fine in that area but organics built up too much i guess:
    barclaya red doing good finally, 2 more leaves should be opened in a couple of days i guess:
    AR varigated doing good:
    Ludwigia sp Red is dying for w/e reason post trim:
    Phishless likes this.
  9. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    Hardware changes:
    Change the Cerges reactor output. Instead of it going in line to to the main pump's output it now goes into the main pump's "intake" / the tetra pond filter box.
    This is attached to the end of the out put and it faces down on the box. Helps direct co2 into the box, prevents it from blowing my pumice stone too much.
    Plant Changes:
    Trimmed the Stauro, gonna try to expand the carpet.
    Might look for a darker carpet to contrast with the stauro, I'm open to suggestions if anyone has any.
    Day Mode FTS
    Nite Mode FTS
    More Nite shots
  10. burr740
    Feb 16, 2015
    1,398
    1,290
    2:41 AM
    Nice!
    Hygrophila araguaia would be a nice contrasting foreground plant
  11. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    I tried araguaia in the past but it never took off for whatever reason. Might give it a go again since the micro dosing has changed
  12. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    so i was looking through some old stuff (my reactor would occasionally be noisy) and I remember Tom mentioning an ozone contact cone for that 17ft tank he set up awhile back. I got curious and wanted one but when i saw the price i said "forget it, i'll try something that might hopefully work in a similar way"
    basing my idea off of this
    decided to use use a Perrier bottle instead of the 1" pipe exiting into a 2" pipe because I wasn't sure if a 1" x 2" Coupling would get the same effect
    will it actually be more efficient than what we already use now? dunno, will probably find out tomorrow afternoon ~ nite
    #52 SingAlongWithTsing, Dec 8, 2017
    Kyalgae likes this.
  13. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    December 12th update:
    Might have to adjust my micro ratio dosages, might not have enough Zn. I'm pretty sure it isnt a K deficiency, I dose about 10 ppm 3x a week.
    3 of the other leaves of that cryptocoryne are in similar condition, snipped off all the heavily damaged leaves
    lagenandra meeboldii red developing holes also
    and the barclaya too
    i doubt these guys are the culprit
    burr740, snarkingturtle and Greggz like this.
  14. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    new years (yeah i know, 1 week late lol) new problems. windelov looking a lil pale and the tips are transparent but it still pearls.
    dunno if its Fe or a Mg deficiency. Don't think Zinc or Boron could do this. anyone know if those Salt water Magnesium test kits work for freshwater?
    still using this fert routine
    #54 SingAlongWithTsing, Jan 7, 2018
    Phishless and Greggz like this.
  15. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    1,032
    956
    3:41 AM
    Got to love it here.:)
    We are all aquatic geeks with our own spreadsheets.o_O
  16. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    gotta keep track of stuff somehow right :D
    Quick video of day mode, just realized my tank is a year old lol
    hbosman, Greggz, burr740 and 2 others like this.
  17. burr740
    Feb 16, 2015
    1,398
    1,290
    2:41 AM
    Boy that water is crystal clear!
    Unless Im missing something I dont see a problem with the java fern tips, they are normally transparent as it grows.
    Also I really like the Lagenandra sorta tucked underneath like that. Its subtle but very interesting when you see it.
    Are you dosing any gluconate, no from what I can tell? Just trying to figure out why some of that stauro is pale. Gluc used to do that to certain species in mine, for whatever reason
  18. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    Owe it all to the 200 micron filter sock, pita to clean though lol
    oh, did not know that lol. i aways start freaking out a lil bit when leaves go transparent
    i don't dose gluconate anymore. yeah i don't understand why some of em are pale either, part of me thinks they might be some old tips/leaves that i never trimmed or they've been hella damaged somehow (back from when i was messing around with gluc). i tied a drop checker to a piece of plastic tubing and stabbed all over the substrate to check if co2 reached areas where i thought would be trouble spots but co2 did reach those areas ¯\_(ツ)_/¯
    #58 SingAlongWithTsing, Jan 11, 2018
    burr740 and Greggz like this.
  19. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    trimmed the tank today, maintenace took 8hrs today lol
    Before
    After:
    Pulled out this piece since it wasnt doing anythign for the scape, it was hidden between the buce hedge and lagenandera
    rzn7z7, Greggz and burr740 like this.
  20. SingAlongWithTsing
    Feb 17, 2016
    145
    154
    12:41 AM
    so i did some math, Mg might be low for my tank.
    with of dGH 14 and dKH 11 I hsould have about 78.662584 Ca and 13.02037561 Mg
    formulas:
    Ca ppm = dKH*17.86*0.4004
    Mg ppm = ((17.86*dGH) - (2.5*Ca ppm)) / 4.1
    Ca is about 40.04% of CaCO3
    Too high of Ca can affect Mg, Boron, and P iirc. Gonna add about 6.98 ppm Mg weekly to see what happens. I have a good feeling about weekly total of 20 ppm Mg for w/e reason
    Nikolyator and Phishless like this.
