Ok - I am attempting to inject O2 when my CO2 turns off. Here is my current plumbing:
1) Filter Intake --> Eheim Pro3e 2078 --> Outflow
2) Surface Skimmer --> Marineland 350 Canister --> AquaMedic 1000 --> UV Sterilizer --> Hydor Heater --> Outflow
3) Pressurized CO2 tank --> Split to Diffuser placed under ROI 50 powerhead for misting and AM1000 Reactor
So I have added a T and some check valves in the airline from my CO2 cylinder. When the CO2 turns off, I have an air pump that turns on. PROBLEM: it does not create enough pressure to get the O2 into the reactor or the diffuser. I have tried a couple different sized Air Pumps with no luck.
Needless to say I am feeling a bit dense. Some possible solutions:
1) Bigger air pump - I am doubtful this will fix my problem... ?
2) Isolate my air injection to either the Reactor or the Diffuser - which would take less pressure to run? The Diffuser is a small ceramic one off of ebay.
3) Add a venturi somewhere in this mess? If so which one would be the easiest to plumb in and how would I turn it off at night?
I am hoping for some simple and practical advice.
