Trying to FIX my Lightning
Discussion in 'Lighting' started by Lightt, Jun 26, 2016.
  1. Lightt
    Lightt Junior Poster
    May 27, 2016
    45
    3:40 AM
    Hello,
    I am trying to fix my lightning to get rid of some problems i am facing such as melosira algae.
    I think that i am on a very high lightning build and this is why i am facing issues.
    My specs are:
    21 gallon aquarium with about 80 liters free water.
    Dimensions on centimeters 80 x 30 x 40
    My height is 40
    Bulbs distance from surface 10 centimeters
    Substrate thickness 7-8 centimeters in general with some slopes being more.
    My lightning setup is 24w x 3 , 6500-4000-6500k from front to back with 2 t5 HO daylight and 1 pink bulb freshpower plants
    My plants are:
    Hemianthus cuba, pogostemon helferi, cabomba furcata, alternanthera red ruby, ranunculus inundatus, fissidens fontanus, alternanthera reinecki mini,ludwigia perennis , Rotala Wallichi
    So what do you think; Is it extreme lightning for this setup; Should i close the 1 t5 ho bulb and run with a 2x24;
    Thank you very much
  2. 1077
    1077 Guru Class Expert
    Aug 19, 2010
    189
    3:40 AM
    I think yes,it is quite a bit of light.
    Would try just two bulbs for a couple week's or forever if the algae subsides.
    Especially if lighting period is longer than eight to ten hours CO2 enhanced or not.
    My two cent's.
    Other option might be to raise the light higher if you are able and again,give it a couple week's.
    Keep filter cleaned regularly (monthly).
    Good fertilizer routine if fish waste is only method currently in play, fish waste alone might not be all that plant's are wanting.
  3. Lightt
    May 27, 2016
    45
    3:40 AM
    Thank you for your answer.
    My light period is now 7 hours...
    This algae (melosira) goes better after cleaning my filter and increase a lot my co2...Lets see...
