Trying emersed
Discussion in 'General Plant Topics' started by JJ..Bequiet, Jun 6, 2011.
  1. JJ..Bequiet
    JJ..Bequiet Prolific Poster
    Jul 19, 2010
    85
    6:19 AM
    While waiting to piece together my 180 I decided to do an experiment.
    [​IMG]
    eleocharis sp. belem from Matt F. (thanks again!)
    [​IMG]
    vase came from marshalls for 4.00 holds 2 gallons of water.
    [​IMG]
    [​IMG]
    covered with cling wrap and have a 13watt cfl 6500k bulb..
    hope it works out..starting to think I dont have enough soil in it.
    I used organic potting soil from the flower bed out front.
  2. ShadowMac
    ShadowMac Lifetime Members
    Mar 25, 2010
    1,043
    12
    6:19 AM
    a quick creative solution for the wait.
    I purchased a small seedling greenhouse from Lowes and filled the tray with some aquasoil. I put it in the window. It is heated from the bottom. It stays moist and I've placed a small bit of most plants I have in there to see which I can get to grow that way. The belem is starting to throw out runners, C. parva does well, its not ideal for stems, but it has only been a few weeks. All of them seem to be growing.
  3. feh
    feh Guru Class Expert
    Jan 14, 2011
    668
    6:19 AM
    I've been considering one those myself. Not ideal for stems I'm guessing because of the height? I'm wondering how that would work out with staurogyne.
  4. chopsticks
    chopsticks Prolific Poster
    Jan 20, 2011
    70
    6:19 AM
    Some stems change form when growing, I have a bunch of Limnophilia sp. growing emersed, they grow a lot more compact and branches a lot more and than in the immersed form.
    Also you don't want them to grow too tall emersed, I think it is better to be constantly trimming and replant the tops so you end with many more plants. Short stem plants are IMO better for planting in the tank later, they have few leafs with in the emersed form.
    I think a container with a height of 10cm to 20cm will give you plenty of room.
    Juan
  5. ShadowMac
    Mar 25, 2010
    1,043
    12
    6:19 AM
    my staurogyne is doing the best i think. the downoi, which i received in rough shape seems to be recovering well, E. belem and E. parvula have sent runners, limnophilia hippuroides is branching with new stems, most look good.
  6. JJ..Bequiet
    Jul 19, 2010
    85
    6:19 AM
    Well I have new growths from the e.belem but at the same time it appears to have some die off as some of the older grass has browning at the tips..would this be die off from transformation to emersed? or a deficiency?
    also some new leaves on a crypt of some sort I placed in with belem.
  7. ShadowMac
    Mar 25, 2010
    1,043
    12
    6:19 AM
    a lot of my belem died off and browned as well. It has new shoots coming up now, however. It may be adjusting. If you see new growth and that looks healthy I wouldn't get concerned.
  8. chopsticks
    Jan 20, 2011
    70
    6:19 AM
    Same happened with some E. parvula that I planted on a DSM tank, it was in submersed in a tank before I planted it in my DSM tank.
    I think all of the old leaves browned out and died, but new leaves come out.
