Currently have 120gal semi high tech planted, no real scheme or idea to it kind of a mish mash of plants, etc...but in a month or so moving up to 180gal range, high tech planted with a plan. Have ordered a good bit of wood from Tom (to go with previous batch from him currently in use) will be trying some things for first time (needle wheel CO2, ATI lighting with burst scheme etc) and ADA Amazonia.
I've only used inert type substrates in past (plain gravel, fluorite, eco complete). Whenever I've moved up from a smaller tank to larger, I simply use the old substrate, add new to it, hook up the same seasoned canister filter, and put the fish in right away.
For this new tank, I'm not re-using the old substrate but I will be using the old Eheim canister on the new tank. Question: does the ADA AS give off nitrates, ammonia etc? I get that impression from the forums that it does. Will my Eheim 2080 be able to handle it, and Can I add my fish (tetras, electric blue rams, plecs, 3 discus) from the old tank right away, or do I need to keep the old tank going for a month (not easy to do but not impossible) or so while the new substrate settles out?
Thanks in advance
Thanks in advance
