Hello dear extra geeky acuaristas:
I'm not sure if posting this in light or in co2. This is a good example of how tightly related are both....
-I've seen posted at tpt this technique of having the photoperiod divided in shorter segments to prevent algae. Is that a myth?
I currently have it 3on 3off 3on, and as I'm switching from co2 24/7 to timed I'm worried that co2 won't build up in 3 hrs of light on.
I know that co2 is important in the first 1-3hrs of light. Therefore my concern.
When The solenoid goes on, it takes about 15 minutes to get some bubbling from the diffuser after the light came on.
This tank is very well oxygenated by surface agitation and is medium light (40-50 par at substrate), then not much co2 is needed to make a big difference.
I've had the light segmented mostly because it works perfectly with when I can potentially stare at the tank without interruptions. Also because I want to prevent algae.
I'm open to come back to one 6hr block of light. If that would help the co2 to build up.
This is a cardinias tank, can't go full throttle with gas. It's currently 1bps in a Mr.aqua inline glass b.counter.
