Biollante, oh right trace and macros should be on different days. Forgot about that. Ooops, I added 1/16 tsp K2SO4, but I meant to add KH2PO4 for phosphate. I get those two confused, so I have the bags labelled with full name, then their "letter number name" and "N", "P", or "K". Hehehe, and I STILL get confused! So dosage of K2SO4 and KHPO4 should be the same as each other?
I just added 1/16 tsp KH2PO4, and another 1/4 tsp epsom salt.
Good point on adding dechlor to the yeast mix. I made a new one up today with Prime for dechlor (it neutralizes ammonia and nitrite too though, so will that kill the food the yeast needs??), and 1 tsp yeast (hahaha), and 1/2 cup sugar in 500 mL warm tap water. Back to basics, I will see what it is doing tomorrow morning.
I am using Flourish Trace until I get some CSM+B, how much Flourish Trace should I be adding every second day?
The TDS might actually be higher than my meter is reading...I have had troubles calibrating it. *grumble*
Gerry, your post did come through, it is back on page 3.
The test kits do read "various numbers" as I use them for my reef tank too. They have also read different numbers in the past when I was testing RODI water, and testing how much to reconstitute it as well. So I know they are working, just probably only as good as a hobby grade kit can be.
I think they read well enough that the numbers should be comparable to each other, just maybe not a known source.
I was thinking of doing a 3 day blackout on the tank. That has helped tremendously a year ago when I battled a really bad case of BGA. Do you think I should consider doing this, or just see how these new changes work for me?
I did remove nearly all traces of BBA, BGA, and Cladophora I could find today. The tank got a pretty good overhaul.
I just need CO2...in a baaaaaaaaaaad way!!!
I will start daily fluffing of the plants too. My plants sure are yellow in comparison to the lush green plants you guys all have!!
