Trace ppm results from garden brand
Bishop
Sep 17, 2017
73
70
40
New Zealand
Probably seems odd to ask but my local supplier is
out of chelated trace mix until end of next week.
I have this 'Trace element's Chelates' made by Yates that's lying around but want to figure out the result of the dose or how much to add.
Is there a formula I can use to find out how much ppm I will be adding to a 220L aquarium per ml or something? Seems like its quite a lot and doesn't have everything but should be okay?
Guarenteed Analysis %w/v
Sulfur (S) as sulphate 0.53
Iron (Fe) as lignosulfonate chelate 0.34
Magnesium (Mg) as lignosulfonate chelate 0.34
Zinc (Zn) as ligonsulfonate chelate 0.34
Manganese (Mn) as ligonsulfonate chelate 0.26
Boron (B) as lignosulfonate chelate 0.13
Copper (Cu) as lignosulfonate chelate 0.043
Mylybdenum (Mo) as lignosulfonate chelate 0.005
Ta
George Keros
Jan 1, 2021
50
Adelaide
Ta
I have the same problem and can fin this on any calculator. Did you ever get an outcome using this Yates mix
