Trying to solve a mystery. I have a 75 FW tank that has been setup for over 2 months. I have had all my community fish in there for around 2 months. I recently decided to order some Discus, SAE, and some more cardinals for the tank. The shipment came on Thursday. The fish were placed into the tank and each bag was acclimated slowly.
*I did not have a quarintine tank setup at the time because the Discus were essentially the fish I was worried about and wanted them in the main tank. Anything from this point on would have been quarintined.*
The Discus were stressed and appeared to be loosing their slime coat so I added more Prime to the tank and also some aquarium salt. The salt I added was a fairly small amount compared to a normal treatment (1/4cup vs 1 cup). I used less due to plants in the tank but I felt the need to help the slimecoat on the Discus mildly. A few cardinals died that night but I chaulked it up to stresses of shipping. I decided to do a 25% water change to be safe.
However, the next day 16 of my 20 cardinal tetras were dead as was 1 Discus! They remaining 4 were at the top breathing heavy like they had ammonia poisoning, but the test kits showed 0 for ammonia and nitrite. I turned down my CO2 which was not pumping out that many bubbles per second to begin with. I removed the 4 remaining cardinals and put them in a bucket with fresh tap water (Primed) and immediately they looked better. This led me to believe that it is definately a chemical poisoning the fish in my tank, not a disease and the cardinals are just the most sensitive.
Could the salt cause some reverse osmotic conditions in a particular plant to release something toxic to fish? I do not own any exotic plants just your standard LFS types. The only other thing I could think of was that 2 days prior to my receiving the shipment of Discus I decided to clean my tank and move some plants around. I had an anubis nana that was covered in spot algae and some hair algae. I removed it from the tank and one end smelled rotten. I cut that end and dipped the leaves in a mixture of H202 and water for ~1hr. I rinsed it with water and placed it back in my tank. Since the incedent, I have removed this plant...just in case it was leeching something into the water.
I did a 25% water change after seeing the cardinals breathing up top, and another 50% change the next day after finding most of them dead. The 4 I moved to the bucket are all doing fine. The other fish were starting to look stressed, hiding, ocassionally breathing at the top...etc. They would look normal for awhile, eat and then go hide. I decided to break down the 75g tank and moved everything to freshly setup 20g tank. I moved a few plants over, and one of my filters.
24hrs later they all look normal. Colors are bright, they are swimming normally and even the 2 surviving Discus are starting to eat. WTF happend to my 75g?! Here are my guesses:
1.) H2O2 plant reaction w/ or without help from aquarium salt (reverse osmosis).
2.) Some fungus remaining on driftwood became toxic...at just the right time...not buying that, but throwing out the driftwood since fungus has not settle even after 2 months.
3.) Something toxic on the outside of the fish bags that were placed in the tank to acclimate. I never even thought of rinsing off the outside the bags before putting them in my tank. Or from the newspapers they were packed in, heat packs...etc.
4.) CO2 even though I trimmed it and aerated with various water changes? I did switch from having the CO2 on 24hr on a pH meter so it would turn itself off once it got to 6.2 to having a timer added so that it was off ~10hrs at night about a week ago. CO2 just does not seem likely especially with multiple water changes.
Any thoughts, ideas, comments, or other insight would be appreciated. I am using this forum as my therapy session.
From now on all bags will be rinsed and fish put into a Q tank. Lesson learned but mystery not solved!
